[email protected] 10 Posted February 21, 2015 Hi Guys, sometimes when i depress my clutch pedal it stays down and i have to pull it back to position by hand. Other occaions it returns on its own. Is there a spring that should be attached to return it, or does the clutch need bleeding? Any help/ advice please. Thanks. Quote Share this post Link to post Share on other sites
steveo29 0 Posted February 21, 2015 can try bleeding it or the m/c or slave is starting to fail Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 21, 2015 Thanks for that. It had been sitting unused for 9 years before i got it going last year. Quote Share this post Link to post Share on other sites
leon263 0 Posted February 21, 2015 can try bleeding it or the m/c or slave is starting to fail As above. I had a similar problem not too long ago and a new clutch slave cylinder cured it. A sub £50, easy repair and if that does not cure it, it will probably be the master cylinder. Quote Share this post Link to post Share on other sites
volksworld13 0 Posted February 21, 2015 Check and operate the pedal by hand ensure its not catching on the plastic trim. Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 21, 2015 Its just dawned on me that there was an oily patch on the ground. But it didnt feel like oil, could be brake/ clutch fluid. Thanks for your replys, help. Quote Share this post Link to post Share on other sites
