turbocorrado94 10 Posted March 7, 2015 what gearbox should i use on the corrado with 1.8 20v turbo conversion, its currently running mk3 golf tdi gearbox but gearbox went last night and needs to be fixed today Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 7, 2015 Have a look in this thread mate. It's probably covered in here, and it'll help you familiarise yourself and understand what's what in the conversion. http://the-corrado.net/showthread.php?t=36117 Quote Share this post Link to post Share on other sites
madmatt 10 Posted March 7, 2015 realy depends on what you want from it as to what gearbox to use.ie is it a toy or being use for track day then the higher ratio options are good lower top speed but more torque available in each gear.for a more relaxed drive lower ratio will give lower rpm and better mpg as per your tdi box. Quote Share this post Link to post Share on other sites
dragon green 4 Posted March 7, 2015 Ni did reply in the "other" thread you started,! This will help http://the-corrado.net/showthread.php?t=31273 Quote Share this post Link to post Share on other sites
