olidavis 10 Posted March 26, 2015 hi guys got a strange one here for you i hope someone out there can help. i bought a non running vr to find the engine has never been run since a full rebuild with cams head rings valves plugs ect oil and filter oil is brand new. it turns over fine but just wont go. i have checked a few things and its had a new crank sensor. i check the ecu inside to find a burnt out resistor or some tiny component so replaced it with another one but still wont go. there are 3 relays missing from the left side of the fuse box but cant find out anywhere that tells me what they are for. the fuel pump doesnt start wen i turn the key so guessing one is for it? it seems to not have a spark wen i crank it but sometimes wen u stop cranking it sparks once or twice. any Quote Share this post Link to post Share on other sites
Ray1965 10 Posted March 27, 2015 Few things to make sure you have got before going any further, continuous and strong spark, fuel going into the bores. Check ignition timing, and valve timing is correct. Have you got compression in the cylinders? These would be the things i would check and then go from there. Quote Share this post Link to post Share on other sites
seanl82 23 Posted March 27, 2015 (edited) Fuel pump relay is 67 or 167, and is on the bottom right. There are a few relays that won't be there, I forget exactly where but the left 2 definitely aren't there mate. Edited March 27, 2015 by seanl82 Quote Share this post Link to post Share on other sites
olidavis 10 Posted April 1, 2015 thanks for the help guys another thing i thought was quite silly but may be normal is the windows both close on their own when ever you switch the ignition off or on? it has had a clifford alarm immob in it but the guy said it was removed?? Quote Share this post Link to post Share on other sites
olidavis 10 Posted April 1, 2015 also what are 99 and 72 for in this pic Quote Share this post Link to post Share on other sites
