Cressa
abs switch disconnected??
my abs light does not come on at all. I've removed the switch and found I have voltage at the 5pin connector, but the red 2 pin connector does not go into anything. I have a strange feeling something has been removed internally so it doesn't light up!! Does that sound reasonable? I have the switch apart and there is a circuit board with 5 pins and an led. What should that red 2 wire plug connect into?? Anything.
And after reading lots, I need to borrow a vagcom reader. As a newbie I'm trying to make this non runner right.
Any help greatly appreciated
After finding and reading more write ups, one suggestion was that the lamp inside was blown. I've soldered a replacement and it only works!!! All be it is on all the time. Time to find the fault
The red connector i think was for the american market mate so there wont be any pins for it to connect to. Sounds like youve found the problem anyway now time to get it scanned on VAGcom
