Dox 23 Posted June 8, 2015 I've got a spare, but can't find it when I need it, is there an online guide to repair the pedal sensors dry solder joints? TIA Quote Share this post Link to post Share on other sites
dragon green 5 Posted June 8, 2015 I don't think there was a guide, D&G or Stealth used to fix them Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 8, 2015 From memory, and I have a terrible one so you'll have to bear with me, it's pretty straight forward, cut the rubbery seal away at the end, pull it apart and resolder the manky joint. Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2015 Well I've found my spare sensor and it has been opened like you say What holds the sensor in the servo? Quote Share this post Link to post Share on other sites
swiftkid 1 Posted June 8, 2015 See that metal clip ziptied to the sensor in the first pic? That holds it in place. You push the sensor in, make sure the seal is seated correctly, and that slot just to the left of 'w3' in second picture is where the clip goes Quote Share this post Link to post Share on other sites
Dox 23 Posted June 8, 2015 See that metal clip ziptied to the sensor in the first pic? That holds it in place. You push the sensor in, make sure the seal is seated correctly, and that slot just to the left of 'w3' in second picture is where the clip goes Mine appears to have a grey foam tape holding it in? Do you just pull to remove it? Quote Share this post Link to post Share on other sites
leon263 0 Posted June 8, 2015 That's about it, remove the circlip which should be there, jiggle it about to loosen it and it should pull straight out. Quote Share this post Link to post Share on other sites
