scruffydubbers 0 Posted June 22, 2004 not sure which section to put this in really but just a quick question just bought a new knock sensor for the g60 and i remember reading that it is important that the torque setting is correct. could somone tell me what the torque setting is. Quote Share this post Link to post Share on other sites
aposegil 0 Posted June 22, 2004 if i rember what Henny said its 15lbs :D correct me if im wrong as ill have to chage it :( Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted June 22, 2004 thanks mate Quote Share this post Link to post Share on other sites
Henny 0 Posted June 22, 2004 yup, somewhere between 15 and 18 LbFt is the norm according to Bentley... I went for a nice straight 15 and it's fine... 8) Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted June 23, 2004 thanks, thought i would change it as it looks pretty old Quote Share this post Link to post Share on other sites
Rpmayne 0 Posted June 23, 2004 Any ideas where the knock sensor is on a VR? Is that the one which changes the timing if the engine starts pinking or knocking? Quote Share this post Link to post Share on other sites
scruffydubbers 0 Posted June 23, 2004 yep thats the one, not sure where it is on a vr tho Quote Share this post Link to post Share on other sites
dr_mat 0 Posted June 23, 2004 There's two on a VR. One on the front and one on the back of the block. I couldn't tell you exactly, but there's no likely to be any other bits with wires coming from them at that point.. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 23, 2004 Follow the wire from the thinner of the two plugs on the rear engine mount to get the rear KS and at the front, follow the wire from the lower of the two plugs, also mounted on the front engine mount bracket. Quote Share this post Link to post Share on other sites
