unclean 10 Posted July 5, 2015 (edited) Unfortunately I blew my headgasket a couple of months back. I'm in the midst of the engine rebuild now and thought I'd just check if anybody has a recently reconditioned or even low mileage VR6 head hanging about before I send mine off? I'm also on the lookout for bits like timing chains, tensioners and gaskets if anybody has unused ones stashed? Cheers, Phil. Edited July 5, 2015 by unclean Quote Share this post Link to post Share on other sites
captainredeye 0 Posted July 5, 2015 That sucks dude, good luck with the build, go for the newer plastic tensioner and bolt with out the nipple on the end but don't by one of the sets if you do this as the newer set is a single chain and not the double. Quote Share this post Link to post Share on other sites
unclean 10 Posted July 5, 2015 Nice, thanks for the heads up. I've got some part details from VAG, but it appears some bits are now end of life. Do you reckon the Febi chains/tensioner parts are sufficient? Quote Share this post Link to post Share on other sites
Dox 23 Posted July 5, 2015 Do Ford still stock VR6 engine bits? Quote Share this post Link to post Share on other sites
unclean 10 Posted July 5, 2015 Very good question actually! I'll check in with the Ford stealers this week. Quote Share this post Link to post Share on other sites
captainredeye 0 Posted July 5, 2015 I think the ones I used were febi And no issues yet, alot of online stores seem to stock febi so I wouldn't personally worry about using them. Quote Share this post Link to post Share on other sites
captainredeye 0 Posted July 5, 2015 One thing I did a lot was go on partsbase.org to get the part code and just type that in on eBay.de the Germans seem to have lots of Om parts lying about. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted July 6, 2015 I've got a Vr6 engine that's been sitting for 20+ years, only had 19.000km before a mate of mine crashed the car.. It's in bits, might be of use to you? Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted July 6, 2015 Some of the kits out there are ideal you just need to make sure it's the right one. http://vwgolfr32.co.uk/shop/VR6-Timing.htm Quote Share this post Link to post Share on other sites
