Richard92 10 Posted July 29, 2015 As topic states im wondering what this ring on my driveshaft is: It seems to be rubberized steel or something along those lines, should i just cut it off? it just hangs loose on there, i assume it once sat here? : Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 29, 2015 Can't see the pictures, but I'm assuming its the anti-vibration damper. It should be a tight fit, and help stop any vibrations at speed. If its loose and you're having no noticeable vibration, just cut it off mate. Quote Share this post Link to post Share on other sites
Richard92 10 Posted July 30, 2015 thanks. How come you cant see the pictures, did I do something wrong there? Quote Share this post Link to post Share on other sites
Yandards 0 Posted July 30, 2015 I can see the pictures ok, also Sean is on the money with the fault identification too. Quote Share this post Link to post Share on other sites
dragon green 5 Posted July 30, 2015 I cut mine off about 6 years ago,if I find a fault without it on there,I'll let you know Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 30, 2015 thanks. How come you cant see the pictures, did I do something wrong there? I'm at work Richard, (literally live here atm!) and most image hosting sites are blocked, so I don't see many of the pictures posted on here. Not something you've done wrong if others can see it mate. Quote Share this post Link to post Share on other sites
Richard92 10 Posted July 30, 2015 Cheers guys! Off it goes! Quote Share this post Link to post Share on other sites
