HummuH
1991 Corrado 20vT Race Car
** PRICE CHANGE ** For Sale - VW Corrado 1.8 20vT Race Car **PRICE CHANGE **
Many of you will know the car from TS Trackdays, SMRC Sports & Saloons and Super Lap Scotland. The car is fully race prepared and is ready to go racing with all the required safety equipment to MSA Blue Book standard.
The car won Class C in Superlap Scotland in 2015 and finished a close 3rd in the King of the Hill Championship. Multiple class B1 winner in Scottish Sports & Saloon Championship.
Highly competitive car, very easy to maintain, reliable and ideal for someone looking to get into track days, sprint events or Saloon Car racing and be competitive in class from day one. The car has been developed and maintained to a very high standard, with no expense spared. Words cannot describe the amount of time, research and money that’s gone into getting the car where it is today.
The car was originally built in 2008 by JabbaSport as their Corrado G60 turbo demonstrator. I purchased the car in 2011 and first raced it in 2012. The car has been constantly developed and modified since then. In 2014 JabbaSport installed a new custom built 1.8 20v Turbo engine. The car is currently SORN but V5 available and could be returned to road use if required.
An outline of the specification of the car is:
Body
1991 VW Corrado G60 chassis
External re-spray in Ford Arctic White in 2015
Custom Livery - wrap and vinyl - can be removed if required by new owner
Sunroof delete
Custom arches
Lexan all round – except windscreen - vents in door windows
LWS Design Lightweight bonnet with MkII Focus RS vents
LWS Design Carbon Fibre tailgate
Lightened doors
Lightweight mirrors
External pull cables for battery cut-off and fire-extinguisher
Modified front bumper to improve air flow to engine and oil cooler
Appx. 970kg wet weight.
Engine - appx 800 miles since new
1.8 20vT currently developing appx. 370bhp and 360lbft/490Nm – built new and mapped by JabbaSport in 2014.
Block re-bored, honed and skimmed to 1900cc running 82.5mm JE forged pistons
Scat H-Beam rods
Gas-flowed head with Supertech valves
ARP bolts all round
Hybrid IHI VF22 Turbo
550cc injectors
Ported Ceramic (internal) exhaust manifold
JabbaSport 3" down-pipe
Custom Pro Alloy Motorsport inter-cooler and radiator
Forge Motorsport silicone hoses
Forge Motorsport dump valve
Baffled sump
Emerald K6 ECU running 3 switchable maps
OBP breather tank
Mocal Oil Cooler
Modified loom
Bosch 044 fuel pump
Mocal dry fuel break kit
Direct cold air feed
Chassis welded Vibratechnics engine mounts
Fluids and filters changed 3 times a season.
Engine was spec’d to run much more power – full details on request
Suspension
AST adjustable coilovers with custom springs and rebound
KW front top mounts
Powerflex Black Bushes
Modified 4x100 hub carriers with SCCH ball joint extenders
SCCH rose jointed ball joints
SCCH anti bump-steer kit
Rear axle shimmed for camber and toe
Neuspeed front ARB
Neuspeed adjustable rear ARB
Brakes
Custom fully-floating 4-Pot AP Racing caliper kit by BG Developments – new 2015
Fully-floating 330mm AP Racing discs with custom bells – front
OEM – rear
Pagid RS4-2 (Blue) – Front
Ferrodo DS2500 – Rear
Goodrich braided hoses all round
AP Racing dual-line brake bias control in cockpit
ABS deleted
Transmission/Drivetrain
VW 02A CBA gearbox with 1st and 2nd ratios from 02A CCM – rebuilt Sep 2015
Quaife Tran-X differential with adjustable ramping - 40/70 with 70lbs pre-load
Custom dog-bone gearbox mount
Short-shift
Sachs 4 plate racing paddle clutch
Balanced driveshafts
GKN CV’s and SKF bearings all round with high temp racing grease
Stud and nut conversion
20mm spacers all round
Wheels & Tyres
8 x Team Dynamcis Pro Race 1.2 17" x 8" ET 20 – one set white, one silver
Will be supplied with 2 x Toyo R888R – 235/40/17 GG Medium compund, 2 x Avon ZZR 215/40/17 medium compound and 4 x Kumho V70 205/40/17 super soft compound. All tyres have good amount of life left in them.
Internal
AIM MXL Pro dash with datalogging via CAN Bus to ECU
Corbeau Revolution seat – new 2015 - in date
HANS harnesses – in date
Lightweight dash with genuine Carbon Fibre inserts
Lightweight screen demister
Switch panel
Odyssey lightweight racing gel battery
Fully welded cage
Plumbed-in 2.5l fire extinguisher
Fixings for passenger seat
Electrical master switch and Extinguisher trigger
AFR gauge
3 way map switch
Spares Package
An extensive spares package that has been put together knowing what is useful to have trackside or close to hand is available separately. Please contact for further details.
The car was extensively rebuilt during 2014/2015 and was then given an external respray in Ford Arctic White in early 2015. The current livery is a combination of wrap and vinyl and could be removed by the new owner. I have shown a couple of images below showing how it looked in white at start of 2015 season.
Any inspection welcome. Loads more information and images available on request.
Price: £14,500 OVNO
Please contact me via PM on here.
Thanks for looking.
Photos of car after 2015 respray
2015 Trophy Haul
Various Images
Edited by HummuH
Price Change 17th Nov 2015
Updated with price change 17th November 2015.
Bargain buy.
How did you get on when you fitted the dropped ball joints and anti bump steer kit?
Did it make a big difference?
Bargain buy.
Sorry man, just seen this. Hard to say to be honest as we changed a lot of things at the same time. What I do know is that the car was faster after we made the changes and the front end definitely turned in better.
Car is still for sale. Huge amount of car and fun for the money. Added a couple more pics to.
Cheers.
