Cressa
Battery jacket for a bigger battery
FOUND ONE.
I'm looking to replace my battery with a Varta silver e38 74ah version. As it is slightly longer than my original one the battery jacket would not fit.
Does anyone know of a larger version with the flap on?
I appreciate people may not use the jacket at all but if possible I would like to.
Thanks for any help
Edited by Cressa
Found one
I've seen some Vauxhall covers on ebay with the same button down top cover that come in various sizes, seem to go for a lot considering most are pretty grubby looking though, perhaps because they seem to be over £70 new from Vauxhall.
http://www.ebay.co.uk/itm/Vauxhall-Astra-G-mk4-mk5-BATTERY-BAG-COVER-CAR-DTI-CDTI-SPORTIVE-VAN-SXI-LS-VXR-/311503175901?hash=item48870940dd:g:R3IAAOxyRhBSzGR4
Edited by davidwort
Okay, so as stated I put a larger battery on my VR Corrado, because it fits in the space !!
Unfortunately that meant the tatty fabric battery cover which comes as standard no longer fits.
So I've always kept my eye out for this, done lots of searches, asked questions but to no avail.
Last week I saw a write up about a Skoda 72ah battery jacket so armed with the part number I went to TPS. Although they couldn't give me dimensions they brought out the battery it is for. I sadly took down all the measurements to check against mine.
Should fit. So I order the VW part and fitted it today.
Result, it fitted and I'm back to the OE look as it should be.
Genuine VW part no. 1K0-915-411-B
I hope that can help someone else too[ATTACH]84837[/ATTACH][ATTACH]84838[/ATTACH][ATTACH]84839[/ATTACH]
Sent from my SM-G900F using Tapatalk
Looks very smart how much was it?
Sent from my HTC One M8s using Tapatalk
About 22 pounds including vat. Bargain I think for a genuine new item as ebay have wanted that for 2nd hand ones
Blooming bargain! Think I better one I've got a large battery myself should keep things looking tidy..
What's you battery dims... from memory mines 170 x 270 x 270 ish.
Thinks mines 270, 180 and around 200 tall so kinda similar?
That sounds right. I've wrote the internal dimensions of the jacket on some paper on the first picture
Think I'll risk it for a biscuit😊
My battery was approximately
18cm wide
19cm high
28cm long
And the fit is great
