MZpog 10 Posted January 5, 2016 My alternator and power steering v belts don't seem to last very long on my early valver and when its very wet (as it often is) they occasionally suffer from slippage which results in a drop in voltage or on/off power steering, depending on which slips. Before replacing them again, I was wondering if its possible/easy and what's involved to upgrade them to a toothed belt system which I believe is found on later valvers? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 15 Posted January 5, 2016 hi m8 I had an issue with my valver power steering belt - occasionally slipping & causing very heavy steering issue was found to be the pulley wheel on the power steering pump, it was deformed in its circularity & causing the belt to be chewed slowly & as such random slipping replaced the pulley wheel & it has been ok since Quote Share this post Link to post Share on other sites
MZpog 10 Posted January 5, 2016 hi m8 I had an issue with my valver power steering belt - occasionally slipping & causing very heavy steering issue was found to be the pulley wheel on the power steering pump, it was deformed in its circularity & causing the belt to be chewed slowly & as such random slipping replaced the pulley wheel & it has been ok since Thanks, I'll have a look at it but I'm sure it's ok and it only happens when wet. Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 5, 2016 How is your tensioner gear? Is it just slackening off a bit when under tension where the gear teeth are worn, so only noticeable when wet maybe......? Quote Share this post Link to post Share on other sites
MZpog 10 Posted January 5, 2016 How is your tensioner gear? Is it just slackening off a bit when under tension where the gear teeth are worn, so only noticeable when wet maybe......? Tensioner gear, teeth? Not sure what you mean. I recall there being a bolt to tighten to increase belt tension. Quote Share this post Link to post Share on other sites
seanl82 23 Posted January 5, 2016 Thats the one, there should be teeth on it that mesh with teeth on a bracket to create the tension. If the teeth are knackered its possible the bolt is slipping back down a bit. Just a thought. Quote Share this post Link to post Share on other sites
