RFvr6 10 Posted February 17, 2016 £380, pickup from Fife, Scotland, can deliver or meet if not too far away see my gumtree link for more info and pictures: https://www.gumtree.com/p/wheel-rims-tyres/vw-audi-tt-comps-alloy-wheels-set-17-5x100-/1155277676 many thanks! Ross Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted February 18, 2016 Hi Ross, Sorry to hijack your post, I have just put a set of comps on a VR and found it has pushed out the centres, did you run spacers on yours? Quote Share this post Link to post Share on other sites
RFvr6 10 Posted February 18, 2016 no don't be daft! I didn't run spacers, that's quite strange how they didn't fit right on yours because iv seen them on a couple other corrado's Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted February 18, 2016 Fronts went on with no issue, but the rears pushed the centres out on the dome top on the hub. Did the same both sides! Quote Share this post Link to post Share on other sites
Dox 28 Posted February 18, 2016 Grrrrallye said: Fronts went on with no issue, but the rears pushed the centres out on the dome top on the hub. Did the same both sides! Maybe its the type of rear disks fitted? Or the bearing caps? Quote Share this post Link to post Share on other sites
RFvr6 10 Posted February 18, 2016 it will be the bearing cups/caps, I don't have them fitted on mine, so that will be the problem! Quote Share this post Link to post Share on other sites
Grrrrallye 0 Posted February 19, 2016 Well that solved that issue then!! thanks guys Quote Share this post Link to post Share on other sites
