KARMANN 0 Posted February 23, 2016 Can anyone confirm if this diagram is the way to wire up the Spal fans in a VR? I pulled it from an old thread but the thread wasn't clear. What size of wire should I use? Regards Fraser Quote Share this post Link to post Share on other sites
swiftkid 1 Posted February 23, 2016 Yep, that is how I've got mine wired. You can start adding resistors etc if you want to retain 3 speed but I didn't bother in the end. Quote Share this post Link to post Share on other sites
KARMANN 0 Posted February 24, 2016 Brilliant, I will get stuck into this. Resistors is a bit above my skill level, I'm happy for them to run at full rate. What size cabling do you recommend? Regards Fraser Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 24, 2016 No need for diodes either Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted February 24, 2016 The wire i used was 25amp 2mm sq 28/30 This: http://www.vehicle-wiring-products.eu/product.php/975/25-amp-2mm-sq-28-0-30 Quote Share this post Link to post Share on other sites
KARMANN 0 Posted February 24, 2016 Ok got cable and connectors and heatshrink. Rad and old fans removed. On the connected left on the car I have a thin red/white wire a thick red/green wire a thick red/black wire and a thick brown wire. What am I bridging together and connecting where? The new fans have a blue and a black wire? Thanks, Fraser Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted February 24, 2016 I started a thread a while ago about spal fams but i cant find the link but if you search on google with the forum name redborbet you shpuld find it Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted February 24, 2016 http://the-corrado.net/showthread.php?90394-Spal-fan-wiring-and-constant-full-speed-dash-switch Quote Share this post Link to post Share on other sites
KARMANN 0 Posted February 24, 2016 Thank you Bill. I've now just got my head around it I think. So the red/white will be from the yellow temp sensor the red/black and the red/green will be from the other sensors? And the brown is the ground? Fraser Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted February 25, 2016 I started a thread a while ago about spal fams but i cant find the link but if you search on google with the forum name redborbet you shpuld find it Red borbet off the forum :lol: Quote Share this post Link to post Share on other sites
KARMANN 0 Posted February 25, 2016 The search for Redborbet returns zero results. Quote Share this post Link to post Share on other sites
sexybourbon 0 Posted February 25, 2016 Billcore found it and put a link up for you on page one mate Quote Share this post Link to post Share on other sites
