dingle 0 Posted March 30, 2016 Hi I'm sure this has been asked already but I have never found a reply to my issue so here goes 1993 Corrado vr6 auto converted to a manual .been having issues with rear spoiler when you hit 45 to 50 it raise few centremetres then stops and few seconds after it raises abit more and so on till it's raised but doesn't always go all the way up. Then it's the same for going down like there's an intermittent fault, If you press the button it does the same thing so I changed the module that arrived today and it's worse than ever even on the button it barely moves but within returning for a spin it seemed to have gone the way down so I'm now out of ideas. Is there a switch on the gearbox or another relay hidden as speedo works fine and everything else is fine, Thanks for any info Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 30, 2016 Sounds like the actual spoiler/motor needs cleaning,have a read http://the-corrado.net/showthread.php?t=51125 Quote Share this post Link to post Share on other sites
dingle 0 Posted March 30, 2016 Cheers i will have a look,was out at weekend and was playing up then next thing it's working tu can hear the module click as it stops then it goes up a little bit then clicks and stops like it's lost power and now changing the module its worse,I removed the back panel off the boot pulled the stop thing out on the motor and it's as free as a bird that's what confused me. Quote Share this post Link to post Share on other sites
dingle 0 Posted March 31, 2016 Update on the rear spoiler I stripped it down tonight cleaned and greased the motor put back in and hey presto still the same issue so that's the motor done the module replaced and still doing the same so no I am confused Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted March 31, 2016 I did all this cleaning malarky and just bit the bullet and bought a new motor for it worked a treat ever since. Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 31, 2016 Update on the rear spoiler I stripped it down tonight cleaned and greased the motor put back in and hey presto still the same issue so that's the motor done the module replaced and still doing the same so no I am confused Did you strip the motor and clean the brushes ? Quote Share this post Link to post Share on other sites
jekel 10 Posted March 31, 2016 Update on the rear spoiler I stripped it down tonight cleaned and greased the motor put back in and hey presto still the same issue so that's the motor done the module replaced and still doing the same so no I am confused Probs. the motor, I've got a spare motor and a spare whole mechanism if ya need, mine went while baqck and ended up buying about 3 good spares. I probs. buy whole thing myself to be on safe side that's what I did Quote Share this post Link to post Share on other sites
mr.ots 10 Posted April 20, 2016 Did you strip the motor and clean the brushes ? The small green component in your picture of the motor internals is the culprit. It's a thermal trip and cuts the power to the motor when too much current is drawn. I removed mine and replaced it with a solid link years ago and never had another problem with it since. The circuit is still protected by the fuse at the fuse box. Sent from my SM-G920F using Tapatalk Quote Share this post Link to post Share on other sites
dingle 0 Posted April 28, 2016 Hi all well I finally bit the bullet today to strip the spoiler motor as it's been driving me insane with its mind of its own. Well took me about 2 hours to strip it down and back together and as of doing it it's now working a treat but for how long no one knows so thought I would share plus wasn't as bad a job as I thought. Quote Share this post Link to post Share on other sites
