p0l1wrath 10 Posted March 31, 2016 Hello, About 2 months ago i was posting about really bad idle issues i had which were finally cured by a new bosche idle valve, however i am still having idle issues... The car idles fine, but then if any throttle is applied, when you release the throttle and the revs drop, they hang maybe 500rpm higher then they should for a few seconds, and then it will settle. When the car is warm, the same issue happens, but the revs don't seem to ever drop back to idle speed. I still have the error code '00533 Idle Speed Regulation Adaption limit not reached' and it always re-appears within seconds if it is removed. I have read the ross-tech and all the listed symptoms, but I'm looking to understand the error description better, what is the adaption limit? and how is it reached? Thanks Quote Share this post Link to post Share on other sites
jekel 10 Posted April 3, 2016 The car idles fine, but then if any throttle is applied, when you release the throttle and the revs drop, they hang maybe 500rpm higher then they should for a few seconds, and then it will settle. Can't help you with error code but isn't the above just because the throttle damper is set too high, especially if somebody's been playing around adjusting it up due to the previous dodgy isv giving a bad idle. If is too high would give exactly those symptons Quote Share this post Link to post Share on other sites
MZpog 10 Posted April 4, 2016 Check your accelerator cable is free and lubed as idle will hang a bit if sticky. See my post on how to lube it for peanuts. http://the-corrado.net/showthread.php?94136-Accelerator-cable-maintenance-for-about-5 Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted April 4, 2016 Ok guys, good ideas, can you buy throttle dampers new? Couldn't find them anywhere? Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted April 4, 2016 Will scan mine again, as i had the same fault and replaced the ISV and it went away. Quote Share this post Link to post Share on other sites
p0l1wrath 10 Posted April 4, 2016 Cheers jim, not even done 100 miles on my new valve, may take a while? Just guessing here... Quote Share this post Link to post Share on other sites
