stuarttaylor37 13 Posted April 19, 2016 Does anyone know if there is a variation in the thickness of the vr6 rear discs? or if there is a fitment issues with the mk4 caliper upgrade? Thanks Quote Share this post Link to post Share on other sites
Cressa 44 Posted April 19, 2016 I've got standard corrado rears and mk4 calipers. No issues, all works great with the correct hoses Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
delfinis38 1 Posted April 19, 2016 I've got standard corrado rears and mk4 calipers. No issues, all works great with the correct hoses Sent from my SM-G900F using Tapatalk Front there is a difference in thickness dependant on vented or solid... Rears should be a standard thickness.. But you can get a variation in thickness on pads.. 15mm and 17mm ring a bell... As long as you have the correct parts for the mark 4 set up their is no problem. Quote Share this post Link to post Share on other sites
