Woodsy_is_back 0 Posted May 3, 2016 (edited) Hello all, finally getting my C back on the road after 8 years gathering dust in the garage, all progressing well, obviously costing me a small fortune but thought I'd rather spend a few grand on my beloved than buy some other car anyway hello again My question is, my 17" rims rub the interior wheel arch, 205 R17 40 tyres on, need some spacers, want then to run flush with the wings and not stick out but need enough clearance to prevent tyre rub To save me going through ordering fitting and finding out the long way that I've gone too big too short what size spacers should I get? Was thinking 40mm? Any help gratefully received Thanks Woodsy H26 GPM Edited May 3, 2016 by Woodsy_is_back Missing info Quote Share this post Link to post Share on other sites
kdub 10 Posted May 3, 2016 40mm will be too much buddy. Nip to halfords and buy a cheap set of spacers like the ones below. 3mm x 2 and also some 9.5mm ones so you can try 3 - 25mm setups to get the stance of the wheel perfect. Also a good way to try them on before ordering proper hub centric spacers. Remember and give yourself 3-5mm of arch clearance for tyre and wheel flex or it will rub when put under too much load round corners or over bumps. I always load up whatever corner with a passenger or 2 and take 4-5psi out the tires to make sure you don't rub hard and ruin tires/wheels and arches. http://www.halfords.com/motoring/car-accessories/wheel-trims-alloys/ripspeed-spacer-kit-3mm-4-or-5-stud?cm_mmc=Google+PLA-_-Car+Accessories-_-Wheel+Trims+&+Alloys-_-293279&_$ja=tsid:60494%7Ccgn:GoogleShopping%7Ckw:293279&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=awrxitll&istBid=tzar&_$ja=tsid:35522%7Ccid:344535124%7Cagid:24345234124%7Ctid:pla-230445360004%7Ccrid:97647066964%7Cnw:g%7Crnd:17843723185843807691%7Cdvc:c%7Cadp:1o3&gclid=CKuho6GNvswCFZEy0wodTsYPSg Quote Share this post Link to post Share on other sites
Woodsy_is_back 0 Posted May 3, 2016 (edited) Not sure that's gonna work out so cheap, £30 of spacers I'm not gonna use but I like the try before you buy idea, I suppose I could mock up using some plyboard just to get the exact width, or if anyone has done a similar mod let me know looking to buy these http://www.europerformance.co.uk/pages/products/product_info.mhtml?product=423751 Thanks for the help, much appreciated 👍 Edited May 3, 2016 by Woodsy_is_back Needs editing Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted May 3, 2016 What's the ET/off set of your rims ? That would help with what spacers you require. I've got a set of 17"x8" ET 32 and never had any problem with rubbing. Quote Share this post Link to post Share on other sites
Woodsy_is_back 0 Posted May 4, 2016 Wish I knew, bought them off Guy Hartley's misses old Corrado, TSW blades - had them for over 15 years Quote Share this post Link to post Share on other sites
harley_steel 10 Posted May 4, 2016 The offset and width is quite often stamped on the backside of the wheel. It is going to be hard to give you an answer without those two pieces of information. Another option is to load up that corner and use a tap measure to try and see how far the wheel currently sits from the arch. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Woodsy_is_back 0 Posted May 4, 2016 Info from TSW 7.5x17 with an offset of 40. The stud pattern will be 4x100. Forgive my ignorance but this means I need a 40mm spacer to counteract the 40mm offset? Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted May 4, 2016 I'd put 10mm spacers on either side, this should solve your problem. Quote Share this post Link to post Share on other sites
Woodsy_is_back 0 Posted May 4, 2016 Thanks for all the help guys, much appreciated 👍 Had some excellent help from Joe at TSW wheels too - very informative and knowledgeable Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted May 4, 2016 http://www.gtsparkplugs.com/WheelOffsetCalc.html Quote Share this post Link to post Share on other sites
