Hofmiester
Passenger side brake calliper
Need a calliper for my mk2 which is running 280mm G60 brakes
I think both 16v and Vr6 are the same but to be sure. Mine says Lucas 54 on it
Anyone have one? Can't believe I need one as I chucked a pair away last year as I couldn't shift em :)
Vr6 caliper, early mk3 vr6 and gti (5 stud without the retaining clip) will be the same.
Sent from my SM-G930F using Tapatalk
Cheers.
I already have a 288 upgrade on the Corrado. This is for my mk2 with G60 brakes.
Durrrr... Forgot to read first post again. Yea, go on eBay and search golf gti caliper and have a look through. Found a few calipers but that looked decent condition
That calliper isn't the right one, it has retaining clips so it's the later one
Guest sam1990rhodes
hof, just wondering how you got the 288mm brakes on the corrado? did you have to go down the 5stud route or did you manage it on a 4 stud? if so how.
My Corrado is 5 stud (vr6) so you just swap the carriers, callipers and disks/pads
