carrots
braided brake hoses
Corrado past mot but been told again the hoses need doing.so thought its about time I sorted them.its a 16v with g60 front brakes.any recommendations.cheers
OEM or Goodridge braided if you want to spend a it more for mainly cosmetics. Standard hoses should last at least 5 years if installed and bled properly, but they are a maintenance item as the rubber will perish and bulge with age.
i was going to go for braided stainless .i am not 100% sure what kit i need to order as ive got g60 280mm front brakes and 1.8 16v rear brakes
You'll need a set for standard G60 brakes then I guess as all the OEM rear callipers are the same. Note that braided hoses can actually be a danger if not checked carefully every year as the inner rubber hose can perish without having any external warning signs to show it.
