odub
All gone, please delete
I have the sunroof still in the car. It does have a broken part on one side that stops it from tilting. Is it any good to you?
Any parts needed?
I am losing my storgage so will need to dispose of whatever is left within the next couple of months
Any parts needed?
I've messaged you mate
It is, but in primer and has had the aperture for the tow eye deleted.
Let me know if you're interested
Would it be a pain to get a pic. The prime is no prob seeing as I'll be painting it anywho...
Hi. Looking for a driver side window motor/ regulator? Do you have one?
I've got one, would you be after postage to South Africa?
Yes. Would that be possible?
Do you have the ABS controller that sits in the passenger foot well? my car wa stood for 3 years and the ABS ECU is water damaged...
I've still got it, not sure which part number it is, will check later
Need a few other bits too, off-side head lamp, number plate light surround, accelerator pedal stop bolt (plastic capped one in the floor), warning triangle that fits the back seat - also looking for a user manual/service book holder.
Ok. I haven't got the headlights or warning triangle. I do have a number plate light surround and pedal stop. The service book holder I should have and will be in grey if that's what you're after.
The part number on the abs ecu is 1HO 907 379
I'll be able to get the parts this Saturday if that's ok
Cheers odub! - do you know what condition the number plate light surround is in? my one litterarly disintigrated in my hand :( - I'll check my ABS unit this afternoon.
Hi, I no longer have this car but most garages or motor factors should be able to help
