Northendroid 10 Posted June 17, 2017 (edited) The oil squirter clearance issue in piston #4 is because it sits lower the the other three cylinders. Drill 8mm hole through the block for oil return of the Gladder Edited June 30, 2017 by Northendroid Quote Share this post Link to post Share on other sites
Northendroid 10 Posted June 30, 2017 (edited) Looks like Photobucket has screwed up a lot of forums they want $400.00 a year to host now :bonk: F**K you! Time for new thread! Update: switch all my pics to Imgur and fixed the thread Edited June 30, 2017 by Northendroid Quote Share this post Link to post Share on other sites
STU175 0 Posted June 30, 2017 thats annoying.... Quote Share this post Link to post Share on other sites
Northendroid 10 Posted June 30, 2017 (edited) Yeah you bet if they were looking for a way get more money I think it's going to backfire on them, I've already downloaded my pictures and transferred them to Flickr and closed my account. They ask why you're closing the account and told to go screw themselves that I'd rebuild my threads before I'd give them a dime. It suck but I'm not being held hostage and have to pay a $400 ransom to post my pictures. That is just bad business! Edited July 2, 2017 by Northendroid Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 6, 2017 Picked up some the parts today from INA for my G-lader rebuild, seals, bearing, Apex strips, lube. Picked up the G-lader oil return line, banjo fittings, custom hose adapter from 8mm bolt to AN-2 Custom adapter will fit into where I've drilled through the block for the G-lader oil return Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 7, 2017 I purchased a cheap bench top sandblaster and some glass bead media. Not 100% where I want it but in time I'll get the parts looking almost new. Two halves of the G-lader: Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 8, 2017 (edited) Got the Corrado a buddy :D Going to drive this until I get the Corrado on the road. 1998 GTI VR6 not perfect but nice solid car, two small rust spot one by the driver's mirror the other on the hood from rock chip, everything else is rust free. Done recently rotors and pads, wheel bearings, ball joints, poly bushing on all but strut towers those are TT's, serpentine belt/tensioner, O2 sensor, new windshield, window regulator, motor mounts, water pump, timing chain. Everything electrical work with the exception of the cruise control. Needs fluids service, new wheels/tires, rear passenger side ABS sensor. Tranny is good no grinding but long throws so that will need attention, motor 242,000 kms but runs strong, came with ST Coilovers, 25mm sway bar. Interior is mint no tears. It was originally a BC (British Columbia) car so didn't see much snow, it's been well maintained/regular services. Edited July 9, 2017 by Northendroid Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 11, 2017 (edited) Picked up some 3-Piece Mille Miglia MM300 17x8 and 8.5, 5x100 - 5x112 adapters 15mm/20mm for the MK3 Yokohama S-Drives, traded the Bentley's with a Vortex member in my area. Edited July 11, 2017 by Northendroid Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 12, 2017 (edited) Picked up the GTI today in Levis, Quebec, was a little anxious about driving a 19yrs old car that I haven't maintained 365 km's, did the pre trip check, tire pressure, oil, powered steering,coolant levels. Fuel it with 91 Octane and went for it, really pleased with the car, no issues on it's first trip. Some general fixes are required to pass the safety, wiper blades, horn doesn't work, CEL was told it was passenger rear ABS sensor, needs wheel alignment and new tires (that's covered). Nail down some rattles, as previously mentioned the long throw in the shifter got to go. Next couple days will be going through it making a parts list. Some body molding need attending to and some require replacement. Swing by body shop to see what can be done about the rust spots. I do like the VR6 exhaust note it is SWEET! Edited July 12, 2017 by Northendroid Quote Share this post Link to post Share on other sites
odub 0 Posted July 12, 2017 Those wheels will look the business on the mk3. It's a shame the corrado isn't five stud Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 12, 2017 Those wheels will look the business on the mk3. It's a shame the corrado isn't five stud Thanks, I agree they'd look nice on the Corrado but I'm still looking at doing a custom three piece with a set of Sebrings Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 13, 2017 So got the wheels on the MK3 going to need to do some fine tuning to eliminate the rubbing on large bumps. :D But REALLY like the look it give the MK3. Had to use the spacer/wheel adapters 5 x100 - 5 x112. Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 13, 2017 Had to fix the horn in the GTI for upcoming safety it turn be being steering wheel clock spring contacts, was full of dirt and grime no contact was being made. Cleaned the contacts with contact cleaner tweaked the contact upper a bit. all works: Next is getting ABS sensors to clear the warning light. Address 03: ABS Brakes Labels: 3A0-907-379.lbl Part No: 3A0 907 379 E Component: ABS/EDS ITTAE 20 GI V00 Coding: 03704 Shop #: WSC 00000 VCID: 2C572FADDC73802165-4A84 2 Faults Found: Quote Share this post Link to post Share on other sites
Northendroid 10 Posted July 13, 2017 (edited) Brought the GTI for a pre-safety today, they failed the wheels (which I was for warn when I booked the appointment) the Ontario Ministry of Transportation is cracking down on car with wheel poke and fender clearance (lowered). I've borrow a set of 15" wheels get by this fail, also need to replace outer tie rod end on passenger side, rear license plate light, wiper blades, rear rotor and pads and right front hose support bracket needs to be secured. All parts are ordered and some on there way. Corrado update: Got the pistons 4 clearance issue with oil squirter solved, oil pump, oil pan, water pump and cylinder head installed. Edited July 17, 2017 by Northendroid Quote Share this post Link to post Share on other sites
STU175 0 Posted July 14, 2017 I love them sebrings! getting closer...... Quote Share this post Link to post Share on other sites
