Bfstrachan 10 Posted December 10, 2016 Just replaced my lower control arms and renewed the inner roll bar bushes. Now refitting the roll bar links to the control arms. Can someone put up a photo of how they are supposed to fit? I am aware they attach to the top side of the arm, but not so sure about the bush. Do you split the rubbers so one half is on topside and the other underside of the arm or is it simply bolted complete to the top of the arm? It's an early 1.8 16v... Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 44 Posted December 10, 2016 I don't know if they are similar, but this is my VR Fitted Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 10, 2016 I don't know if they are similar, but this is my VR Fitted Sent from my SM-G900F using Tapatalk Thanks for the reply pal! Looks like they are different arms. Mine has a circular hole in the control arm, definitely a different design. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 10, 2016 Pulled this photo of the internet, but can't quite make out if the bushes are both above and below the arm or both above... Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 44 Posted December 10, 2016 The sides must be handed, so was wondering if you confirm the correct side wishbone, would the wishbone Bolt hole then give the answer. !! Just a thought Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted December 10, 2016 Should be a bush under looking at this. http://www.realoem.me/Volkswagen/RDW/COR/1995/76/R/4/407/97010 Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted December 10, 2016 Should be a bush under looking at this. http://www.realoem.me/Volkswagen/RDW/COR/1995/76/R/4/407/97010 That's the one!!! From that image it looks like the two rubber bushes are either side of the arm. That's lovely! Thanks lads! Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
