GazG60 0 Posted December 30, 2016 94/95 Dash panel, where the radio fits. Must be good condition. Also VR6 abs lamp , part number 535919285BA, the one with two plugs tia Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 5, 2017 I don't have a spare mate, but am aware that on this model the lamp inside it fails. I soldered a new bulb in and it worked perfectly. Others too have done that. The bulb isn't anything special, I gone one that looked similar from an autospares shop...cheap as chips repair if you can use a soldering iron. Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 5, 2017 Thanks for the reply. Sadly I have nothing inside the lamp casing. I need a working lamp. Thanks Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 5, 2017 Oh damn. Well the little 2 pin red plug does nothing. ... so I don't see why any other switch wouldn't work !! Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 5, 2017 I've read that as well. I've seen a lamp with a slightly different part number. I might take a gamble on it. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 5, 2017 If mine packs up again that's what I'll do. Let us know how you get on. You could always swap out the back of the switch casings so the red plug clips in somewhere. Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 5, 2017 Yes will do. Do you know if the centre dash panel where the radio and heater controls sit are the same one early and late cars? I've just bought a '95 VR6 and need that panel. And a few other bits. Sun visors for one. Tia Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Cressa 44 Posted January 5, 2017 They are different, so you need a late panel. Difficult to find. . especially without any damage/broken tab fixings. Although if repaired the fixings aren't seen. I have a good drivers sun visor with the sliding part at the mirror of you can't get sorted. Contact lillfuzzer on here as he normally can help with parts Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 5, 2017 Thanks. I'll double check on my driver side visor. How much is it should I need it please ? Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 9, 2017 Thanks. I'll double check on my driver side visor. How much is it should I need it please ? Sent from my iPhone using Tapatalk Bump Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 11, 2017 Hi there, I got the lamp with one plug today. Sadly the pin pattern is totally different ! So still searching for the correct lamp Quote Share this post Link to post Share on other sites
GazG60 0 Posted January 16, 2017 Hi there, I got the lamp with one plug today. Sadly the pin pattern is totally different ! So still searching for the correct lamp Bump Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
GazG60 0 Posted February 12, 2017 94/95 Dash panel, where the radio fits. Must be good condition. Also VR6 abs lamp , part number 535919285BA, the one with two plugs tia Bump Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
