Bfstrachan 10 Posted February 2, 2017 Just put the car through MOT. One of the fail points was "smoke level" the CO/HC/ idle were all pass. When I changed over my KR for the 9a, should I have put a cat into the exhaust system? Since the 2.0 16v all have them... Do I have something else that needs attention? Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
seanl82 23 Posted February 2, 2017 I didn't think it mattered what you have engine wise on a pre (March 91?) as it's before cats became a legal requirement in the UK. Worth googling and doing a bit of research into the subject though. What was the level recorded? Quote Share this post Link to post Share on other sites
Dox 23 Posted February 2, 2017 EMISSIONS HELP CO high, co2 low hc high, o2 high - rich mixture with ignition misfire CO high, co2 low hc high, o2 low -faulty thermostat or coolant sensor CO low, co2 low hc low, o2 high - exhaust leak after cat CO low, co2 high, hc low, o2 high - injector misfire, cat ok CO high, co2 low, hc medium to low, o2 high - rich mixture CO high, co2 high, hc high, o2 high - injector misfire, cat not working, combination of rich mixture and vacuum leak CO low, co2 high, hc low, 02 low, good afr and cat operation- system normal . lambda typical range 0.97 to 1.03 [ ideal lambda 1 ] The emissions limits to be met are specified for both the fast and normal idle tests. At fast idle, CO must be at or less than 0.2%, HC at or less than 200 parts per million (ppm), and the lambda value(1) must be between 0.97 and 1.03. At normal idle, CO must be at or less than 0.3%. Quote Share this post Link to post Share on other sites
Dox 23 Posted February 2, 2017 Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Bfstrachan 10 Posted February 3, 2017 Thanks for the replies guys! It's a 1990 car. I have literally just done the conversion and turned the key. The timing is good, but I have done nothing as far as tuning etc. I kept the KR fuelling and management, but changed the cams from 9a to the KR ones. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
