tony_ack
Wanted - VR6 nsf hub knuckle and hub with ABS
Garage didn't tighten up the hub nut properly when changing the front wheel bearing... result is destroyed wheel bearing with its remains fused to the hub and steering knuckle, and worn grooves in both. Does anyone have a near side front knuckle and hub near Leeds? A newish bearing would be a bonus, but I've got a replacement bearing either way. Thanks
Hi Tony I may have a hub knuckle for that side here in bishop or it will be in Barnsley with vaghag
Sent from my SM-G357FZ using Tapatalk
Okay mate, if you could let me know, and if it's with you, how much it would be to post?
Thanks
Ant
If Chris can't sort you, i've Got both sides.
Cheers.
For once mate got there before you
I'm always hovering close by.. ready to pounce..
