VR6 Lee 0 Posted March 20, 2017 Since my car has come out of its winter hibernation I am getting a clicking noise from the engine. The noise seems to be coming from the area marked in black but without taking the manifold off I can't really see anything. The noise is like a switch clicking on and off. There is no pattern to the clicking noises.. it will happen say at 1 seconds and then you might get 5 in a row and then off for 13 seconds and then only 1 click... very strange Any idea? Quote Share this post Link to post Share on other sites
robrado974 1 Posted March 20, 2017 Probably sticky tappets . Mine has not been started for around 6 months due to work being done on the car .I knew it would be tapping and clicking a bit . It's now been started around 6 times and left to warm up.shes now back to her quiet self when starting. Put a vid up for people to hear the noise . Quote Share this post Link to post Share on other sites
Jim 1 Posted March 20, 2017 Yep stick up a video so we can have a listen. Quote Share this post Link to post Share on other sites
VR6 Lee 0 Posted March 20, 2017 I'll try and get a video of it tomorrow. will be hard to hear it with the engine noise Quote Share this post Link to post Share on other sites
Harrier 1 Posted March 20, 2017 Plug lead arcing? Quote Share this post Link to post Share on other sites
coullstar 0 Posted March 20, 2017 So its intermittent? Could be tappet if its not been used for a while. Did you drive it at all and did it go away? Quote Share this post Link to post Share on other sites
vagstuff 13 Posted March 21, 2017 Plug lead arcing? Yeah, per Harrier earlier, ie : Plug lead arcing ? a likely suspect indeed, as I had very similar symptoms recently of a variable & intermittent 'clicking' / 'spitting' noise, and an accompanying misfire that was accentuated under heavy load at low revs - issue traced straight to one HT lead that had developed a break-point at its connector housing ... ... my arcing 'clicking' noise & its misfire were completely sorted with new HT leads I hope this helps, Lee, and that your situation proves to be a similarly easy fix Quote Share this post Link to post Share on other sites
Tigerfish 10 Posted March 21, 2017 Ditto the plug lead arcing. Start the car up in the dark, it'll be easy to see if it is arcing. Quote Share this post Link to post Share on other sites
