reggiebaby
Top mounts
One top tip is to give the struts a coat of waxoil as the coating corrodes quickly. I found out about it to late.
I'm going power flex on mine. Well you let us know what the ride is like on the aps, as I thinking of getting some .
Will do mate but don't expect to be on the road for a month or so.
More than happy with mine on a G60. Not to harsh but firm enough to have some fun.
Did you replace mounts oem, the more I read the more confused I get been looking at upgrading to vr mounts.
I actually used the top mounts that were already on the car. I didn't think about it until it was to late as I was using it as a daily at the time. But will be changing them when I take them off again to give them a clean up.
Front (for VR6 anyway) are still available from the dealership. This is what I used, although with both top plates it worked out at over £80!
Rears are obsolete, so the next best offering and which I believe is what VW use if genuine parts aren't available, are Lemforder. I think it was AVS / VW Spares that I got them from when I replaced mine last year.
