potatonet
YAY my headgasket is blown, its odd but I'm happy
now I know where the leak is, how many hours will it take my mechanic??? or should I do it myself? well it is pretty neato, I like my blown headgasket.
Nows the time (and the perfect excuse), to get all that head work done...
Full rebuild
Big bore valves
Porting Flowing
New cambelt/tensioner
Inlet Manifold flowing
Exhaust manifold flowing
Oh, might as well replace that gasket too :lol:
Wouldn't like to say how much the work will cost you (not the above, just getting it running again) Because you don't know what damage awaits you underneath. You won't get any accurate figure until they've inspected it.
HTH
which engine have you got? That makes a HUGE difference on the time and costs... :roll:
For reference, I've just done the head on my G60 (again, long story as to why) but in all, it's cost about £130 + £25 machining costs to get the head back onto the car (I actually spent £50 on machining 'cos I needed something else done too ;) ) I did all the work myself and it took me 2 evenings... one to strip it all apart, and one to put it all back together again...
ALL parts are genuine VW (including coolant.... :roll: - don't ask! )
I have no idea how much parts are in America compared with over here though... :?
Yeah I looked at just parts for the car, its about 400 US dollars but the includes, copper headgasket, new head bolts, new head studs by ARP, new cam lifters (mine slap), camshaft seals, intake gasket, I think that was all, but thats just parts, two evenings huh? how hard is it to get the studs and bolts out, should I leave the stock G60 studs? and I do need it to be machined, probably just to get the warp out of it. but I think I will probably port and polish the bad boy too, bigger valves are worthless probably the port and polish too, I am doing a 16V conversion on the thing soon, wish I could do it now but I cant, too much money. how and should I clean the pistons while I am in there, I dont know what to use to clean them. but I could do it over a weekend? not too bad beats 900 dollars toward the mechanic, just like my heater core.
anyone got a good website or instructions for replacing the headgasket I have a bentley but I think I could use better instructions.
I actually think i have a blown head gasket as well =/
Soo, ya wouldn't mind some tips or instructions or what not as well.
Yeah mine was blown I just fixed the thing yesterday. New COPPER headgasket from BBM gotta use lotsa sealant. the head was remilled and the cover was dipped and glass beaded, same as the intake manifold, it looks sooo cherry.
yes the copper is better for the headgasket because it is solid copper, it doesnt blow nearly as much as the crappy fabric stuff. its meant for high boost applications, being that I am pushing 18 lbs of boost with a 65mm pulley I kinda needed something that would last. permatex makes a copper gasket sealant with copper inside, its tacky forms a good bond.
