fla
Starter motor speed
I fitted a new starter last year aeound november. Itvused to turn the engine over very quickly indeed but now seems to jave slowed down a bit. Is this normal? Sounded like a little turbine in the beginning!
Check your battery voltage,earths conditions if all good. Put a meater on your battery and see what the voltage reading is when you crank the engine it should not drop below 11. Volts
Voltage is around 11.8 battery is new. Got an exchange unit from gsf. Bosch.
11.8 volts is nearly flat. Give it a charge.
A Corrado is for life, not just for the MOT.
Checked it earlier it was 12.3volts. But put it on charge anyway so I'll see again in a few hours
Ok. If it was down at 11.8 and that was the resting voltage, with literally nothing turned on, and it's recovered to 12.3 with nothing happened in between then I'd be a bit worried for the state of the battery. Definitely put it on charge. Consider getting one of these:
http://www.ebay.co.uk/itm/371876076928
Edited by dr_mat
