pj027235
injector adjustment?
I have done some research and have found suggestions that it is possible to adjust the injector delivery quantity from inside the metering head. Has anyone done this? I did an injector test recently and found the quantities to be slightly different, it would be nice to have them all the same. Any info would be much appreciated.
The car is a 2.0l 16v with ke motronic bosch CIS.
Are they new injectors?
I had inconsistent injector performance on one of my 8V GTI's with the same KE injection and it was the injectors... replaced them and all was good.
Try swapping the feeds and see if it follows?
MZpog, how old are your injectors?
Absolutely no idea. They came off a running car but can't give any more info than that.
Ok, I am going to try and run a cleaner through my injectors, the spray pattern could be better....if you have done this any recommendations on what to use?
As the age of your injectors is unknown would you accept £15? I don't need the lines, just the injectors....
Would do. You might as well have the lines too for spares. PM me.
Shame you don't need a flowed head as that's taking most my room up, lol.
