robrado974
The little cover strip plastic joiners .
Afternoon chaps .
I’m looking for the corner cover joining bits for the strip of plastic that covers the top of the rear window . I only need one , but will buy a pair if you don’t want to split them .
Kind regards
Rob
You can get one side through heritage Rob
Ok thanks Sean , will take a look now .
It’s probably me Sean , I can’t find it .
I’m on about a different part mate . Sorry my fault .
Inside the car , at the top of the rear screen is a plastic cover strip, sitting right next to the glass . As it joins the left and right upright parts there are two joiner capping pieces. On a side note , the parts you put up have gone up a lot , I paid £2.00 each for those from TPS , they have faded too
Ah yeah, I know the parts you mean. One of mine has broken so has had to be bonded on too.
Were they always bonded on ?, I suppose they must be , otherwise the joiners would be floating in the air .
They clip over and under the strip. You should be able to slide them a bit
Sent from my E5823 using Tapatalk
Yep I know what you mean , mine has never been right . One of those niggles
That’s the one chris , the drivers side is missing, don’t think they are sided though .
Leave it with me mate
Sent from my SM-G357FZ using Tapatalk
Thanks mate
Thanks mate
It’s ok chris I found the little joiner in the rear footwell. The sprayshop must have put it back together but it fell off .
