Grum
H & R Cup Kit Suspension
Ive had the H & R kit installed on the VR but the mechanics are saying the fronts arent sitting correctly in the top mount cup. anyone got ideas as to why?? the rears fit fine btw
You need to fit the earlier upper spring cup, they changed the cup and spring diameter on later cars but uprated springs continue to be made for the early set up
cheers dox. when you say earlier cups, are you meaning earlier vr6 or earlier corrados in general, 1.8, 2.0 etc
Early VR6, The part number info is on the forum, but I can't find it atm
I'll second dox's info. I too found I needed the earlier spring caps when I fitted uprated springs to my later VR. On the plus side, someone will always purchase the later caps from you
Cressa
Sent from my SM-G900F using Tapatalk
i think im right in saying the smaller cups are p/n 1j0412341 and the larger cups are 1h0412341.
Sent from my SM-G920F using Tapatalk
Yes mate, I believe so. Goodluck in sorting it
Hi. What are your thoughts on this kit? Comfy, crashy, well made etc.
Cheers
good handling, nice and flat in the corners. the ride is firm but bearable. im still not to sure about the drop though, wish it was a little lower
Cheers mate.
They sound quite promising. Was it 40mm drop?
Cheers mate.
im happy with them but like i said, wish they were a little lower. the description said 40mm yea. iirc if you couple them with powerflex top mounts they give an extra 10mm drop
