dazzx10r
My Corrado 1.8 20v turbo build
Not a good start to the weekend, as I went into the garage I could smeel petrol. A quick glance under the car revealed a nice pool of petrol.
[ATTACH=CONFIG]91855[/ATTACH]
The leak was coming from the accumulator pipe that was quite rotten, so no option for it I had to take the pump assembly down to investigate further. Seems that wasn't the only problem. The plastic pump housing was also cracked, admitedly made slightly worse as I was wrestling to remove it.
[ATTACH=CONFIG]91858[/ATTACH]
[ATTACH=CONFIG]91861[/ATTACH]
So a bit of clever plastic welding with the soldering iron ensued, follwed up with a coat of epoxy resin.
[ATTACH=CONFIG]91864[/ATTACH]
[ATTACH=CONFIG]91867[/ATTACH]
A bit of an update, I've managed to get the intercooler pipe welded up and fitted, I'm just pondering sending it off for powder coating now.
[ATTACH=CONFIG]91978[/ATTACH]
Also fitted my carbon air intake, it's a Simota one off my old BMW 328 Msport. I made a little bracket for it and secured it to the intercooler pipe.
[ATTACH=CONFIG]91981[/ATTACH]
I'm just waiting on a silicone hose arriving now for the recirc valve.
[ATTACH=CONFIG]91984[/ATTACH]
I've also been a little bit busy in the back of the car.
I made a strut brace with the mountings welded to the strut towers.
[ATTACH=CONFIG]91987[/ATTACH]
And boarded the rear bench seat area out around my battery after reloacting it to the back of the car. I need to source some carpet now and carpet over it all. I'm trying to make the back of the car look something like the Audi TT Sport Quattro.
[ATTACH=CONFIG]91990[/ATTACH]
I see you haven't posted in a few months but I have been looking for the guide that you mentioned on club gti and I cant find it, any chance you could share the link? Thanks.
It's been a while since I last posted on here so here's an update to where the car is now.
A change of plans with the interior, I have decided to go back to the factory look and reinstall the rear seats and carpet. The battery has been moved to the nearside rear corner on a custom made battery tray.
[ATTACH=CONFIG]95185[/ATTACH]
[ATTACH=CONFIG]95186[/ATTACH]
[ATTACH=CONFIG]95187[/ATTACH]
Edited by dazzx10r
Which brings things back up to date Unfortunately a change of plans means that the car is now going up for sale, I'll be sorry to see it go as I had every intention of keeping it for good but I simply don't have the free space to keep it and couldn't bear to see it sat outside on my drive rusting away.
