Lucassayers7
Any other front brakes for g60
I keep trying on different rims and cant get them to fit due to the brake carrier being so close to the mounting hub i need spacers to clear it, i see most front calipers dont have such a big carrier that sticks out so far. wondering if Audi or a different vw front brake bolts up to an g60 hub and would fit rims that are 15's around it. need new pads and rotors and the rear caliper i had to rebuild, so switching the calipers, carriers, rotors and pads would be good. any suggestions?
I had the circle cut out racing steelies barely messed the carrier with 25mm now I have D cut out diamond steelies makes it with a lot of space on 25mm will figure out how much it almost touches.
How much are those, and do you have a link to a good supplier?
Another idea is shaving the carrier bar down quite a bit would this cause brake failure under heavy braking? i do see alot of open faced mounts without the bar.
Edited by Lucassayers7
