[email protected] 10 Posted February 11, 2018 Had the dash out to replace the heater blower fan. All good eventually. Now all the dash is back in the ABS light is illuminated. Any suggestions why this may be? Or was there always a fault and I’ve just highlighted it. Thanks guys. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
Dox 23 Posted February 11, 2018 Check relays and fuses behind the glove box Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 11, 2018 Ok. Thanks. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
George Lee 10 Posted February 11, 2018 I've just had problems with my abs. Check fuses are ok behind the glove box and test there getting power with s multimeter. Also test the relays. My problem was the ecu was water damaged so didn't work. But should be something minor if it was working before you took the dash out Sent from my SM-G950F using Tapatalk Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 13, 2018 HELP please. What are my options, can I drive it ? Is it a new ecu or pump. Bit panicky cause I’ve got it booked for a track day end of Feb. Any suggestions very welcome. Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
Dox 23 Posted February 13, 2018 Swapping the pump got rid of my inlet / outlet valve faults. I had 7 faults and I suspect it was down to a power supply issue within the pump Quote Share this post Link to post Share on other sites
GrahamV 10 Posted February 13, 2018 Try disconnecting battery neutral only, and then re-connect a few minutes later, this should reset ABS ECU. Also check pump mounted resistor is intact and connected Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 13, 2018 How much are pumps, can the be sourced from anywhere ? Sent from my iPad using Tapatalk Quote Share this post Link to post Share on other sites
Dox 23 Posted February 13, 2018 Mine was £30 used bought off this forum 5 years ago. I believe the wiring will just reach a substitute pump without removing the old one for testing before swapping it out Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 14, 2018 Tried the battery thing. No luck. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 14, 2018 Any abs/ecu units for sale for a VR6 Corrado. ‘94. Thanks. Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
red arrow 0 Posted February 15, 2018 Any abs/ecu units for sale for a VR6 Corrado. ‘94. Thanks. Sent from my iPhone using Tapatalk PM Sent Quote Share this post Link to post Share on other sites
fendervg 32 Posted February 16, 2018 Those faults are unlikely to be ECU related, but are more commonly on issue with the ABS pump unit itself. Either a stuck valve solenoid or damage to the loom connector and printed circuit board. If the ECU was damaged you probably wouldn't be reading any fault codes from it. The pumps can be tested, and if repairable, refurbished by the likes of BBA-Reman. Alternatively you could just chance a second-hand unit. They were still available new from VAG the last time I checked, but at the price of a new car! Quote Share this post Link to post Share on other sites
spen 0 Posted February 16, 2018 Got mine refurbished at BBA, 180 quid or thereabouts I think it was Quote Share this post Link to post Share on other sites
robinw 0 Posted February 16, 2018 Got mine refurbished at BBA, 180 quid or thereabouts I think it was I had a similar problem with my previous Corrado. I changed the brake fluid and this solved the problem. Quote Share this post Link to post Share on other sites
[email protected] 10 Posted February 16, 2018 Mine was reverse of yours. I changed the fluid and then the fault appeared. Lol Sent from my iPhone using Tapatalk Quote Share this post Link to post Share on other sites
