Jimboslice 10 Posted February 26, 2018 It's not the firmest and takes just under a second to pop back when released. I can't remember how it felt before. No gearbox repairs done as far as I know. And no I'm using my 16v flywheel with the vr6 clutch kit. Flywheel worked fine before. Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 4, 2018 Okay as an update: I've poked an endoscope in the inspection hole and everything looks okay (although it's too dark to see the TOB touch the PP). I've raised the wheels off the ground and put my clutch pedal in whist in gear and my wheels rotate slowly. I'm gonna order a vacuum bleeder and try that. Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 22, 2018 Still in desperate need of help, PLEASE! I've bled with a vac bleeder, nothing. Fabricated a bit of threaded rod as a manual slave cylinder to ensure the fork moves over: nothing. Took the box off and everything works completely fine, no issues that I can see. Friction plate is the correct way round. I'm going to swap the gearbox and then the clutch. Failing that i'm gonna set it on fire and claim off the insurance. Is there a way to check if the gearbox is broke i.e failed syncro's? I can change gear with the wheels off the ground. Quote Share this post Link to post Share on other sites
Dox 23 Posted March 22, 2018 Try clamping the flexi near the gearbox, the pedal should be solid if all air is expelled from the line. Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 22, 2018 My hydraulics have been proved to be fine. I've bypassed the hydraulics with a threaded bar to push the clutch fork in. Quote Share this post Link to post Share on other sites
dragon green 5 Posted March 22, 2018 Did you check the clutch fork ? They are known to bend ! Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 22, 2018 yeah I've checked and it's straight! Has anyone had a gearbox that won't select gears? wondering if the syncro's are gone Quote Share this post Link to post Share on other sites
Dox 23 Posted March 23, 2018 Not going in gear with the engine running but all gears selecting with the engine off is a classic clutch issue, the pressure plate is still holding the friction late close enough to the flywheel to rotate the gears inside the gearbox making it impossible to select first gear. What's the set up, o2J MK4 gearbox, G60 solid flywheel and VR6 clutch? Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 23, 2018 You say that but I can drive up and down the drive on the clutch in gear. Got an 02j box, both 02a and j towers, 16v 9a flywheel, vr6 clutch, mk2g60 slave and braided clutch line direct between cylinders. I had the box off today and there's nothing out of place at all Quote Share this post Link to post Share on other sites
Dox 23 Posted March 23, 2018 You say that but I can drive up and down the drive on the clutch in gear. Got an 02j box, both 02a and j towers, 16v 9a flywheel, vr6 clutch, mk2g60 slave and braided clutch line direct between cylinders. I had the box off today and there's nothing out of place at all So what are you going to try next? Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 23, 2018 Swap my 02j for my old 02a and if that don't work buy a new clutch for a laugh. If that don't work set fire to my car and claim on insurance Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 24, 2018 Is a 9a flywheel the same as g60? Quote Share this post Link to post Share on other sites
Dox 23 Posted March 24, 2018 Is a 9a flywheel the same as g60? I wasn’t sure so searched CGTi site yesterday and it seems so. Where did you get the clutch from? Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted March 25, 2018 No problems with the flywheel then and I've got g60 flywheel bolts. I got it from eBay (I know I know) last year when I didn't know much about clutches. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted March 25, 2018 Flywheels are indeed the same, bolts are all the same too. Quote Share this post Link to post Share on other sites
Jimboslice 10 Posted April 3, 2018 Managed to sort it. Swapped the clutch over to a new one and it works. I've got a feeling it might of been the retaining clip as I didn't realise you're supposed to but the bottom bit on the fork as well as through the hole! Quote Share this post Link to post Share on other sites
GrahamU 6 Posted April 4, 2018 Glad you got it sorted, everyday's a school day :) Quote Share this post Link to post Share on other sites
