vr6monkey
Headlight Adjuster - 535941297 - WANTED
Hi,
Long shot, but does anyone have a spare headlight adjuster - 535941297 ?? Alternatively, a headlight rear section with an adjuster in it that is still in one piece?
Tried to gently adjust mine for MOT and the white base bit exploded into 10 pieces...
If not, does anyone have any good suggestions (I've seen the 30mm washer & 6mm square nut solution suggested by sam1990rhodes, which seems a good option).
Thanks in advance,
James
Two electric Hella beam adjusters that would eliminate the problem permanently..
I've got a few spare ones. If your interested, send me your email and I'll snap a few photos. There's no way I hell your gonna remove the fixed beam adjusters without them crumbling into bits, I've tried loads of times..
Cheers-Andrew
Edited by VEEDUBBED
