unclean
Wanted: VR6 coilpack engine loom or immob bypassed late ECU
Hi folks,
I'm changing my car from dizzy to coilpack, but the ECU and engine bay loom I have aren't compatible.
So I'm looking for a coilpack engine loom ('93 onwards/pre '95).
OR an immob bypassed late ECU.
Thanks! Phil.
You need the right ecu for your engine. Ag is the early coilpack (without immobiliser) and cp is the late (with immo). From memory there is a tab on the ag ecu so you can't plug it in, think I cut it off when I bought wrong ecu years ago but then you have a different maf so won't run 100%
Sent from my SM-G930F using Tapatalk
Hey Phil, I changed mine from OBD1 to OBD2 so I have the OBD1 ECU and loom somewhere in my garage, the fabric tape needs a bit of tidying up but it should all be there. Mine is '94 so shes a coilpack VR6
If eugopnosaj has no luck finding the loom, I took should have a coil pack engine loom from my old '95 VR6 going spare. It's the piece of loom from the big round multi-pin connector which goes to the injectors, etc etc.
You can still buy it new as well ;) - mine arrived a few weeks back.
How much was it mate?
Hi folks,
Thanks for the info.
I managed to find an appropriate AG loom nearby and have refurbished it with Tesa tape :thumbleft:
Best, Phil.
