Chris at Pottiemill 10 Posted June 22, 2018 I need a front subframe for a 1991 Corrado G60. Does the subframe for a Golf Mark2 fit? Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 22, 2018 (edited) This is the part number for the MK2 Golf / Jetta subframe 191199315AD (1984 to 1992) Eng codes PL KR 9A but does say for all MK2 models. I believe the MK2 and Corrado 4 cyl subframes are very similar, whether they are interchangeable I'm not 100% sure. Below are the measurements of the MK2 subframe. Length 925mm Width 520mm Height 170mm Weight is roughly 10KG From what I've read on other sites people say that the 2 subframes in question are changeable. Here's an old thread from 2014 regarding G60 subframe. http://www.the-corrado.net/showthread.php?89172-Need-front-subframe-for-g60 Also here is a link to the Club GTi forum, showing the differences between the subframes in question. https://www.clubgti.com/forums/index.php?threads/corrado-16v-g60-vr6-subframe-differences-with-pics.267070/ Hope this helps Si Edited June 22, 2018 by vw rule Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted June 23, 2018 I have one from a 2.0l 16v if thats any good Quote Share this post Link to post Share on other sites
