tonedef
VR6 Power Steering Pipe
Looking for the pipe from the pump to the steering rack, nut on mine is rounded at the rack end.
Also wanting a steering rack but plenty of Mk3 Golf ones available on eBay unless somebody here has a good one to sell.
Part number
536 422 891 F
£209.00 euros
(Says for Corrado VR6 RHD only)
Hydraulic hose/pipe goes from steering rack to T-piece near battery.
(Male screwed end at rack)
(Push on fitment at other end)
Length 600 mm
Note! The pipe above has two half's to it, the part number above is for pipe from rack to plastic T-piece.
The other half of the above pipe changes to a rubber hose, which is on a different part number, which goes from T-piece to metal pipe on left side under radiator.
The metal pipe under radiator is
Part number 535 422 896A
£95.95 euros
(For all Corrados)
Part number
536 422 893 C
£289.00 euros
(Says for Corrado VR6)
Hydraulic hose/pipe goes from steering rack to power steering pump.
(Banjo fitment at steering pump end)
Says vin n.o F 50-P-003 451>> onwards
Length 1840 mm
Part number
535 422 888 B
£59.95 euros
(Says for Corrado VR6 1992 onwards)
L-shaped rubber hose from power steering reservoir to T-piece connecter in main return / feed pipe near battery.
Part number
535 422 887
£76.95 euros
Rubber hose goes from metal pipe under radiator on right side, to power steering pump.
Part number
535 422 887E
£62.95 euros
Same rubber hose as above
(But says G60 / VR6
also says up to vin n.o F 50-P-012 501)
Part number
191 422 371B
£22.96 euros
Power steering reservoir
All in stock at Classic Parts but if you speak to VW Heritage, they should be able to pin point correct pipe/hose, if you give them your reg or vin number.
Hope this helps
Si
  vw rule said:
Part number
536 422 893 C
£289.00 euros
Length 1840 mm
Hope this helps
Si
Thanks for the reply, this is the one I need, I'll check the VIN but as mine was at the back end of production in May 95 it generally falls into the latter numbers! I sent annavr6 a PM last night to see if I can buy it through Heritage or if I have to go direct to Classic Parts, I need the car for our daughters wedding the middle of next month so no time to lose getting in bought and delivered.
Cheers
