Baz6701 10 Posted July 26, 2018 Hello folks, seems my G60 is out to annoy me, put a wee post up a couple weeks ago moaning about my car ‘strangling’ itself when I accelerate. I’ve changed the Fuel pump as advised by my local mechanic, no difference, Changed the Blue Coolant Temp Sensor thing, no difference, Changed the plugs and leads, got a bit of smoke now on acceleration but still strangles itself, Changed the battery, starts easier Got a Fuel Regulator Valve to fit but I make houses etc so don’t even know where to look for that under the bonnet PLEASE HELP hahahahaha Quote Share this post Link to post Share on other sites
robrado974 1 Posted July 26, 2018 The FPR , will be at the end of the fuel rail , passenger end , so to speak . Quote Share this post Link to post Share on other sites
Simeon 0 Posted July 27, 2018 What have you checked? I'd be looking at the throttle body to make sure the wot switch is operating correctly and there's no vac leaks in that area. Have you disconnected the lambda sensor to see if it runs any differently? Quote Share this post Link to post Share on other sites
Baz6701 10 Posted July 27, 2018 I’ve only really checked the leads and plugs, the ‘WOT switch’? What and where and how? Nope not disconnected the lambda sensor, that easy enough and again where and how? Cheers for your help Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 27, 2018 Wide Open Throttle. Its not a switch just for WOT though, its a throttle potentiometer, and measures the entire movement of the butterfly. Its the electrical bit attached to the throttle body. Lambda is a real pain to remove, its in the middle section of the exhaust and the heat cycles pretty much weld it to the exhaust. You'll need to specific tool to remove it. Follow the cable though up to the plug which is attached around the rear engine mount and disconnect it there. Quote Share this post Link to post Share on other sites
Simeon 0 Posted July 27, 2018 Yeah, I was only suggesting disconnecting the lambda plug, not removing it from the exhaust. As above, it's normally attached to the rear engine mount on a little clip, easy to reach Also Sean, are you sure you're not confusing the WOT with a VR6, I thought on the G60s it was just a microswitch, similar to the idle switch, that was hit on full throttle :scratch: Quote Share this post Link to post Share on other sites
Bauhaus 3 Posted July 27, 2018 As Simeon says the WOT is just a micro switch, it does not measure anything, it just sends a signal to the ecu to ignore the Lambda readings at fully open throttle. Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 27, 2018 My apologies with the WOT switch, I tend do go into auto and forget there are other types than the VR6! :bonk::lol: Quote Share this post Link to post Share on other sites
Baz6701 10 Posted July 27, 2018 Wow you guys really know ur stuff! Thanks, ok so next question what am I looking out for when I disconnect this lambda sensor and what do I need to do once I’ve disconnected it? Thanks again 👍 Quote Share this post Link to post Share on other sites
Simeon 0 Posted July 27, 2018 All you're doing is removing a sensor from the system that may be giving a bad signal, which is resulting in running issues. With it disconnected you need to drive the car and see how it has been affected. If it appears to run much better then next step would be to replace the lambda sensor and reconnect it. They're about £50-60 so not too expensive, but as Sean mentioned, they can be a ******* to get out of the exhaust! Quote Share this post Link to post Share on other sites
Baz6701 10 Posted July 27, 2018 Magic, ta So hope that’s all it is, worried it’s something more horrible coz the wife will flip her lid hahaha Quote Share this post Link to post Share on other sites
1200 bandit 10 Posted July 28, 2018 As Simeon says the WOT is just a micro switch, it does not measure anything, it just sends a signal to the ecu to ignore the Lambda readings at fully open throttle. Check the wiring to the throttle body l found the wiring snapped (copper wire inside but looked OK from the outside).the is a clicking from thr switch on top of the throttle body when the throttle is opening/ closing Quote Share this post Link to post Share on other sites
Baz6701 10 Posted July 31, 2018 Ok tonight was eventful, I disconnected the lambda sensor in the engine bay and took it for a spin to see if the ‘stuttering’ was gone, which it seems to be however I turned the car off and reconnected it to take it for a another run to see if it was jst luck but the car did not restart only let out a single click and the oil light flashed aaaahhhhh what is up with this thing? Quote Share this post Link to post Share on other sites
Simeon 0 Posted July 31, 2018 So only a click of starter motor solenoid when you turn the key? As long as it's not an immobiliser issue then it's likely to be a bad earth. Remove the earth strap from the gearbox and give it a good clean, then the same for the battery terminals, starter motor and alternator wires. Presume you didn't bump start it? Quote Share this post Link to post Share on other sites
Baz6701 10 Posted August 1, 2018 Ye single click, looks like the earth is a wee bit dodgy anyway to be honest it’s been done with a connector block. Didn’t try bumping as the battery is brand new. Will try the alternator wire etc too, thanks. Could I have blown a fuse reconnecting the sensor? Thanks Quote Share this post Link to post Share on other sites
Simeon 0 Posted August 1, 2018 No, you can't do any damage just disconnecting/reconnecting the lambda. I reckon you want to get rid of any chock blocks in your earth wires! Quote Share this post Link to post Share on other sites
fla 9 Posted August 1, 2018 Tried tapping the starter solenoid? If it just clicks it may be stuck Quote Share this post Link to post Share on other sites
