Jon_vr6
Vr6 outside temp sensor
Noticed my outside temp sensor wasn't showing on the dash so had a look and noticed a break on the plug (blue plug) that connects to the temp sensor. So I think that's the problem any one have a spare plug off the loom I could have? Or anyone know where I can get a replacement from.
Cheers Jon
Edited by Jon_vr6
You should be able to remove the pins from the plug either with jewellers screwdrivers or the proper pin removal tool.
Can you send me a pic of the profile front on so the pins can be seen. Got quite a few 2 pin plugs so should have one that would fit. Although it might not be blue!
