Popeye775
Fuel Injectors
Which engine? Unless you are running forced induction on a VR or modding a G60 I'd say go with what came on the car.
Your best bet if its a chip and pulley tune your doing is to go for those generic Bosch red top injectors, I think there known as "30lb" injectors, Bosch part number 0 280 150 945 and used in some fords over where your are located across the pond, just don't buy any "red top" injector.. go by the Bosch number, remember its not just fuel flow you have to think about, the compatibility of the injector with the ECU is very important.
There are other ones to use depending on your state of tune, I'm using the Bosch 0 280 150 431 injectors.
