baff
2.0 16v 9A ECU vacuum
Hi guys,
I have a newbie question
Does the corrado 2.0 16v 9A has a ecu vacuum line?
I have some idle problems, cleaned the ISV, and after looking thru the forum I saw that the ecu vacuum line for G60 and VR6 is sometimes the issue.
I looked at my ECU and I just don't seem to find one.
Thank's for the support!
Ok!
So... this is what the back of my ECU looks
[ATTACH=CONFIG]96534[/ATTACH]
Should I plug the ECU vacuum in this hole?
Is it supposed to have a plug of some sort?
Thanks!
Hello there,
I don't think the 2.0 16v has a vacuum hose going to the ECU, the G60 has so the ECU can measure the vacuum advance or the boost.
But like I say the 1.8 16v and 2.0 16v Corrado's don't normally have a vacuum hose to the ECU.
There sometimes is a black or green plastic/rubber bung / plug,
in the back of the ECU but not always,
i.e to seal the hole you are showing in your photo.
Si
