Keyo
Vibra front engine mount + H & R springs
Hi Guys,
For sale H & R lowering springs and Vibra Technics front engine mount.
These came off a 95 Vr6 , there getting on a bit but in perfect working condition
The shocks could do woth a powder coating but in perfect working condition.
The Vibra engine mount in perfect working condition .
Would accept £60.00 on collection .
West Midlands
Cheers.
[ATTACH=CONFIG]96542[/ATTACH]
https://www.vibra-technics.co.uk/vw/corrado/340/VAG950M/front_engine_mount_vr6
[ATTACH=CONFIG]96544[/ATTACH]
Edited by Keyo
How much do the springs lower the car by and what shocks did you use them on? Cheers
These came off a 95 VR6 and had some koni sport shocks, the shocks Absorbers were no good anymore . It will lower the ride height between 25 mm - 30 mm , I believe you need the early spring plates pre facelift to work with lowering springs on a corrado maybe another member can confirm this. It says on the spring that they also fit a Golf MK 3 VR6. I believe they will work with stock shock absorbers or any of the Bilstein range, but if your oe shocks are knackerd it will make the ride harsher then it should be.
Described as best in class.
Link for springs and description.
http://www.veedubmachine.co.uk/h-r-lowering-springs-30mm-vw-mk3-golf-and-corrado-vr6.html
Cheers.
Edited by Keyo
Cheers for reply, just weighing up options as want to drop my VR a little, but don't want to use cheap coilovers. Would you be prepared to sell the springs separate and roll them up in cardboard and courier?
I would rather have them collected and sold as a package to be honest Simeon , also the purchaser can inspect them first and make sure they are happy with them.
Cheers,
