Jamie
Centre console tabs
Don’t suppose anyone has come up with a convincing repair for broken tabs on the centre console? I’ve got two snapped on the heater dial mounting.
If you've still got the broken parts you can plastic weld them with a soldering iron. I sometimes slice off thin strips of the item to be welded so you know the material is correct. Ive also used some stainless mesh in the melted plastic.
Hi Hasan - nice to see you still around mate :) I did think about plastic welding but think I’d better have a practice before I end up with a melted mess. That’s a brilliant idea about using shavings Fla. I was hoping someone had come up with some sort of bracket or flip solution but looks like I’m going to have to be that man :D
Those tabs are a real pain - one is broken on mine and I tried to bond it back on, but it broke again in no time. I wonder if you used plastic or fabric/felt washers and made sure not to over-tighten the screws, as they seem to break when unscrewing?
I’ve bodged it with Araldite and Milliput for now. Seems solid enough...
Thanks for the kind words Jamie.
I'm sure your repair will be perfect!
