Stone0311
Drive Shaft Heat Shield
Hi, looking for a driveshaft heatshield for a KR/PG engine - it's the one mounted low down on the back of the block to protect the inner cv joints from the manifold
Thanks
Pretty sure the 3 location bolts are in the same place on all 4 cylinder blocks of the era mate. I definitely have a couple in my lock up, but not sure when I'll next be up there, will check back here to see if you still need one next time I'm up there.
I've had a look on VW ETKA and VW Classic Parts, looks like there's two slightly different part numbers.
For MK3 Golf / Corrado / Passat 1988 onwards
Part number 357 407 721A
Length = 155mm
Width = 140mm
Height = 115mm
Bolt holes are at a 45° angle
For MK3 Golf / Corrado / Passat 1989 onwards
Part number 357 407 721B
Length = 145mm
Width = 140mm
Height = 140mm
Bolt holes are level parallel
I think most of the 4 cyl Corrado's use
357 407 721B
Hope this helps
Si
