r0adrun3r 10 Posted January 24, 2020 Current getting this and idle speed regulation adaption limit exceeded. I have replaced the camshaft sensor with two different sensors just to make sure. I have 12v from 1-3 pin the connector and 5v from connector 2 (signal wire.) I have checked line 2 to the ecm pin 44 and even the solder point on the back of the board and im getting Continuity. Is this possibly a broken ecm ? i have checked everything at this point but does anyone have any tips ? I have even cut the 5 v cable at the connector and ran it straight to the ecm. Is there anything else i can check without a oscilloscope? Quote Share this post Link to post Share on other sites
Dox 30 Posted January 25, 2020 I seem to remember someone in the past had a cam chain sprocket without the sensor pick up fitted? Quote Share this post Link to post Share on other sites
r0adrun3r 10 Posted January 25, 2020 I haven't looked at the sensor pick up tbh as it doesnt mention it in any of the books. Cheers for the heads up ill take a look tomorrow to see if i can find anything. Someone has told me it may be another sensor cause it to bug out but not too sure where to start with that. Quote Share this post Link to post Share on other sites
