Westr 10 Posted February 13, 2020 Hi everyone, I’m after the following part 1H2 927 129 K25 bulb holder with green bulb for an automatic Corrado VR6. Searched everywhere online with absolutely no joy. Does anybody have one I can purchase? I’m also in need of the bulb on the dash to indicate if I have full or dipped beam could anyone tell me if this is a special bulb that I need to locate? Thanks for any advice. Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 You can still get the bulbs mate from VW Classics Via Heritage got one last year. I believe you have written the wrong number for part. Im pretty sure Arz tuning do the bulb its called a diode I think. Should look like this but in blue. Could be that your headlights are not functioning correctly. Should be a common part I guess if its a diode. Quote Share this post Link to post Share on other sites
Westr 10 Posted February 13, 2020 2 minutes ago, Keyo said: You can still get the bulbs mate from VW Classics Via Heritage got one last year. I believe you have written the wrong number for part. Im pretty sure Arz tuning do the bulb its called a diode I think. Should look like this but in blue. Could be that your headlights are not functioning correctly. Should be a common part I guess if its a diode. Hi I got that part number from vw heritage Germany they told me they didn’t have one. Did you get yours from another vw heritage site, could you send me the link? Regards Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 This is the part number for the blue high beam it is not a diode. 357919062 Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 Sorry is a diode. Quote Share this post Link to post Share on other sites
fendervg 32 Posted February 13, 2020 The bulb for main beam is a standard incandescent filament bulb with two wire coming out of the base - it slots right in. The blue is a plastic cap that sits over it. All the others are LED types, but back in the day blue LEDs weren't generally available. I remember I got both the bulb and the cap from the dealers, but that was 8 years or so ago. For the light for the the automatic shifter trim illumination (if that is what it is) have a look on some of the US parts sites, as there were more automatics sold there than anywhere else. Quote Share this post Link to post Share on other sites
Westr 10 Posted February 13, 2020 Ok thanks that’s great that sorts the dash but the other number was for a bulb to illuminate the automatic shifter, I’m desperate to get it working is this what you managed to get from vw heritage, sorry for any confusion. Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 I'LL sort it for you mate hold on- if the green is not available skoda did one in clear light. Quote Share this post Link to post Share on other sites
Westr 10 Posted February 13, 2020 1 minute ago, fendervg said: The bulb for main beam is a standard incandescent filament bulb with two wire coming out of the base - it slots right in. The blue is a plastic cap that sits over it. All the others are LED types, but back in the day blue LEDs weren't generally available. I remember I got both the bulb and the cap from the dealers, but that was 8 years or so ago. For the light for the the automatic shifter trim illumination (if that is what it is) have a look on some of the US parts sites, as there were more automatics sold there than anywhere else. Ok shall give it a go. I’ve been looking everywhere even found one ordered it only to be told they made a mistake and no longer have it and refunded me. Alternatively has anyone found a workaround and put in an alternative bulb? Quote Share this post Link to post Share on other sites
Westr 10 Posted February 13, 2020 1 minute ago, Keyo said: I'LL sort it for you mate hold on- if the green is not available skoda did one in clear light. Sounds promising keyo. You could be a lifesaver. Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 Part Number is 357919243A K25 for the ashtray and I think that the auto is the same bulb ? ??? https://www.ebay.co.uk/sch/i.html?_osacat=0&_odkw=mk2+golf+16v+clocks&_from=R40&_trksid=m570.l1313&_nkw=357919243AK25&_sacat=0 Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 Also this from a Skoda but clear light but will probably be still available form Skoda dealers as was used in later models. https://www.skoda-parts.com/spare-part/357919243d-ashtray-light-bulb-oe-8069.html Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 https://www.volkswagen-classic-parts.de/en/lampentrager-a9e128.html Still available from classics. Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 Part number you posted is not a part number not sure where you got that information from. 1 Quote Share this post Link to post Share on other sites
Westr 10 Posted February 13, 2020 Ah mate I had no idea it would be the same bulb as the ashtray you wouldn’t believe how long this has been driving me nuts thanks so much Quote Share this post Link to post Share on other sites
Keyo 47 Posted February 13, 2020 Spend some time on this site and you will be more helpful to yourself then any customer service from VAG and Heritage, I have to tell them they are incorrect all the time . http://www.oemepc.com/tvn_result/search/tvn/357919077B Quote Share this post Link to post Share on other sites
Westr 10 Posted February 13, 2020 5 minutes ago, Keyo said: Spend some time on this site and you will be more helpful to yourself then any customer service from VAG and Heritage, I have to tell them they are incorrect all the time . http://www.oemepc.com/tvn_result/search/tvn/357919077B Brilliant I shall do in the future. Quote Share this post Link to post Share on other sites
