slim 0 Posted April 12, 2020 Alright dudes, So the great lockdown rebuild has started today and it's been no end of dramas! Been sat too long on the drive! More parts required! 😔 Quick question about changing the crank pulley bolt... I'm either being a mong or my pulley doesn't appear to have a bolt in the middle?? Just the four bolts around the 'hole'. And no it's not snapped already as there is no hole for a bolt to go??? I've taken a pic if someone would kindly tell me how to upload a pic on here. 😁 Cheers, Slim Quote Share this post Link to post Share on other sites
Dox 23 Posted April 12, 2020 Most use the Tapatalk app for pics Quote Share this post Link to post Share on other sites
seanl82 23 Posted April 12, 2020 There should be a 'insert other media' drop down menu at the bottom right when you select the reply box Quote Share this post Link to post Share on other sites
Simeon 0 Posted April 15, 2020 Which pulley are you talking about? The crank pulley (drives the cam belt) has a hole in the middle to put the crank bolt through and 4 tapped holes to attach the drive belt pulley / dampener (drives the 6pk belt for charger/alternator). You say you have 4 bolt holes so you must be looking at the drive belt pulley. Quote Share this post Link to post Share on other sites
